Fuel filter - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Fuel filter (/showthread.php?tid=8925) |
Fuel filter - Jchism3406 - 05-13-2023 I have a 2000 Peterbilt 379 with Cummins isx. I’m only seeing a Fuel/water separator on it with a plug. Is that normal? RE: Fuel filter - Pd6cas2 - 05-14-2023 My CM570 also had the same deal when I first bought it, they IFSM has a bowl plug instead of main fuel filter! Just replace bowl with main Fuel Filter, fleet guard preferably and top off filter with clean diesel before install. There’s also screen filters on the fuel line going into IFSM , I bet yours are pretty dirty by just running 1 filter! RE: Fuel filter - Jchism3406 - 05-14-2023 Do you Happen to have a fleet guard fuel filter number. I keep Coming up with a 1040. Also do You Have the number for a screen? RE: Fuel filter - Pd6cas2 - 05-15-2023 (05-14-2023 )Jchism3406 Wrote: Do you https://www.fleetguard.com/s/productDetails?propertyVal=FS1007&queryTerm=Fs1040&language=en_US https://www.fleetguard.com/s/productDetails?propertyVal=FS1040&queryTerm=Fs1040&hybridSearch=true&language=en_US I run Mostly FS1040 because of Minnesota winters’ and I buy them in Bulk 12pack. The fuel line screen is serviceable if not damaged used carburetor cleaner or equivalent. Also replace all O ring gaskets on the fuel line removed. One more filter is located under IFSM facing down, Its has a cap with another screen filter serviceable again unless damaged. |
