Changing tire size in insite - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Changing tire size in insite (/showthread.php?tid=8927) |
Changing tire size in insite - suined - 05-14-2023 Could anyone guide me where to change the tire size on insite to correct a speedometer reading slow? I can’t seem to figure it out RE: Changing tire size in insite - suined - 05-17-2023 Anyone? RE: Changing tire size in insite - Pd6cas2 - 05-18-2023 I believe it’s the RPM section, You will need to know what Your new tires RPM is . Michelin is typically 527 |
