| Repairing trailer harness rot. Take a look. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: Repairing trailer harness rot. Take a look. (/showthread.php?tid=895) |
Repairing trailer harness rot. Take a look. - preacherboy24 - 09-17-2016 I use hot glue to seal up my work. I get the wire and solder up the connections. After I trim the solder down I use hot glue to seal up the work. So far its been pretty effective in keeping the harness rot down. I completely rewired my trailer after all the issues I had with the old harness. Another trick I learned was to use silicone ADHESIVE to hold your harness in place. I tucked my harness in places where there is no chance of pinching and simply gooped on some silicone adhesive and is stays in place pretty well. https://www.facebook.com/dennisjr.stotts/posts/10207038803719773 RE: Repairing trailer harness rot. Take a look. - preacherboy24 - 09-17-2016 This is what it looks like after its done. |
