Injector leak down test. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Injector leak down test. (/showthread.php?tid=8954) |
Injector leak down test. - Markos19 - 06-12-2023 I have a Cummins ISX15 CM2350 engine and I suspect I may have a leaky injector or two. Can I use the same Cummins tool as in the video for my engine? If so where is the fuel metering actuator located on my engine please? RE: Injector leak down test. - tree98 - 06-12-2023 The CM2350 has a common rail fuel system, it's completely different than the 870/871 that uses the actuator's. To do a proper leakdown test on a common rail engine you need the cummins insite (version 8.3 or newer) program and an inline 6 adapter. These things can easily be found on eBay and other places on the web. RE: Injector leak down test. - Markos19 - 06-12-2023 (06-12-2023 )tree98 Wrote: The CM2350 has a common rail fuel system, it's completely different than the 870/871 that uses the actuator's. Thank you so much for the reply. So is there any tool I will need other than the datalink adapter? Like something that will go directly on the engine component? RE: Injector leak down test. - Rawze - 06-12-2023 (06-12-2023 )Markos19 Wrote: ... this is all you need to do for a leak down test on a common rail ISX. No tools required outside of software (cummins Insite) and an adapter ... http://rawze.com/forums/showthread.php?tid=8728&pid=75483#pid75483 |
