no power to ac clutch - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: no power to ac clutch (/showthread.php?tid=8960) |
no power to ac clutch - BCODERRE - 06-17-2023 ac worked last time we had a heat wave. 2 weeks later no power to ac clutch. fuse ok, pressure ok, replaced high and low pressure switches. still no power to clutch. any ideas would be appreciated. RE: no power to ac clutch - Rawze - 06-17-2023 related to your other issues mentioned here>?.. http://rawze.com/forums/showthread.php?tid=8772&pid=75759#pid75759 Maybe this helps too.. http://rawze.com/forums/showthread.php?tid=8277&pid=72161#pid72161 RE: no power to ac clutch - DVT873 - 06-19-2023 Year and VIN? RE: no power to ac clutch - Satch - 06-24-2023 Sounds like what i just went through. RE: no power to ac clutch - BCODERRE - 07-01-2023 2012 prostar VIN 3HSDJSJR8CN555546 RE: no power to ac clutch - Bengy88 - 07-01-2023 Do you have the a/c fault message on the dash? Do you have any sort of diagnostic sw to connect to it and see what the fault message is if you have one? Sometimes on these pro stars you have to reset them after the a/c is repaired or you won’t get power to the clutch. I’ve had luck with removing the battery cables for 15 minutes to do so. RE: no power to ac clutch - BCODERRE - 07-01-2023 Nothing shows up in the info center, but I am going to disconnect the batteries. RE: no power to ac clutch - Aleeex - 07-15-2023 What were the pressures? RE: no power to ac clutch - BCODERRE - 07-18-2023 Sorry for not getting back in a timely manner. I found the problem. A complete IDIOT some time in the past stuck the tip of a test light into the insulation of one of the wires that run from the high side pressure switch. It was hidden under the wire wrap. Repaired that and it works fine now. Thanks for all the help! |
