Braking issues - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Braking issues (/showthread.php?tid=9049) |
Braking issues - volvokid - 08-17-2023 Hey drivers got me a code causing a headache!!! This is a ISX engine and the code is sa 0 spn 1818 fmi 31 Its causing the truck to continuously lock up my brakes... has anyone had or have this issue and if so howd you fix it? Thanks and any help or advice is greatly appreciated!! RE: Braking issues - Bengy88 - 08-17-2023 Sounds like you have a yaw rate sensor or steering angle sensor issue |
