ATC light - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ATC light (/showthread.php?tid=912) |
ATC light - 1mattrichert - 09-21-2016 so my atc light wont shut off and console is reading out abs ecu fault. anybody ever had this issue? RE: ATC light - Waterloo - 09-21-2016 I did, in my proStar, it was my compass module if you can believe that. You think I would have figured that one out? Hell no, not in a million years. What kind of truck and what year. If it is in the canbus system, a trip to the dealer may be in order to figure out which module is bad, if that is the issue. RE: ATC light - Brock - 09-21-2016 mine does it when it rains RE: ATC light - 1mattrichert - 09-21-2016 2013 kw t700 RE: ATC light - Mrkentee - 09-21-2016 I had it. On mine it was the steering angle sensor, located under the steering wheel, around the steering shaft. 2010 Peterbilt 386. If it's Bendix, you can download the program for free, and the inline 5 will access it through the ECM port. (Hopefully you have that. If not, most shops do, or somebody on here.) Once it was replaced it needed to be calibrated, which I could do with my laptop and inline 5. Hope this helps. RE: ATC light - 1mattrichert - 09-21-2016 thank you |
