International LT625 headlights stay on all the tine - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: International LT625 headlights stay on all the tine (/showthread.php?tid=9140) |
International LT625 headlights stay on all the tine - victory26 - 10-04-2023 Hello everybody, I have a 2021 International LT625 that has some weird headlights issue. The headlights stay on all the time with both the low and high beams at the same time, even though the switch is in the off position. The headlights stay on even if you unplug the light switch completely. I tried swapping the light switch from a sister truck that is exactly the same, comes from the same fleet. Also swapped the body controller from that same sister truck, all with no luck. If somebody had same issue please pinpoint me in the right direction. Than you! RE: International LT625 headlights stay on all the tine - ktblogistics - 10-04-2023 on cascadia with chassis module when no communication with chassis module lights are on and turn signals blinking, maybe something wrong with communication with modules and truck sends a signal about it RE: International LT625 headlights stay on all the tine - Rawze - 10-05-2023 Do they shut off with the key switch?... It might just be the daytime running lights that you are referring to .. and newer trucks are programmed often so that they stay on always, or stay on once you hit the switch one time. They will also often come on and stay on if the daylight sensor (a small black sensor) in the dash just under the windshield is covered up by someones junk that is laying up there and covering it.. or if the sensor has gone bad. Prostars are also known to have ghost issues like that if the fuses in the fuse pannlel are tarnished. here is some info on this: http://rawze.com/forums/showthread.php?tid=1514&pid=12861#pid12861 RE: International LT625 headlights stay on all the tine - victory26 - 10-05-2023 The lights won't turn off even if the key is off nor with the truck locked. That sensor is clear , there's nothing covering it! RE: International LT625 headlights stay on all the tine - victory26 - 10-13-2023 Local dealer found some rubbed wires that were touching on the steering colum where the steering wheel tilts. Thought I'll post and let you know what the problem was. RE: International LT625 headlights stay on all the tine - Rawze - 10-14-2023 (10-13-2023 )victory26 Wrote: Local dealer found some rubbed wires that were touching on the steering colum where the steering wheel tilts. Thought I'll post and let you know what the problem was. tanks for the follow up. RE: International LT625 headlights stay on all the tine - JMBT - 10-16-2023 When that happened on my 2012 Volvo VNL it was the LCM, (light control module) going bad… I replaced it and it fixed the issue |
