Windshield Wipers - Printable Version
+--- Thread: Windshield Wipers (/showthread.php?tid=9147)
Windshield Wipers - fgm3028 - 10-15-2023
2017 Prostar with all of the normal electrical gremlins and then some. Now my wipers will only work on high. When on intermittent the relay pops but nothing happens. The push to spray that normally activates the wipers does not activate wipers but the spray does work. Did buy a new motor to have when I got home but after hooking it to the wire harness without installing it the problem seems to be the same. Do not have access to computer to check it out and really do not want to pay International their typical high prices unless a last resort. Was hoping that someone had a similar issue and a possible solution. Thanks Frank
RE: Windshield Wipers - tree98 - 10-15-2023
https://rawze.com/forums/showthread.php?tid=8772
