Software for New Holland tractor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Software for New Holland tractor (/showthread.php?tid=9149) |
Software for New Holland tractor - PuroCumminsPower - 10-15-2023 I am looking for a program to diagnose an issue with a tractor I have. It's a New Holland T4050F. I have a Cummins Inline 6 adapter. I have the adapter that hooks up to my tractor. I have Calterm and Insite. I used to have Jpro. Is there a program that someone can recommend? Thanks. RE: Software for New Holland tractor - windowrattler - 10-16-2023 I think what you want is CNH EST software. As far as I know the only adapters that work with it are the CNH adapter and DPA5+. I have no hands on experience. This is the link to the OEM website for reference for you. https://www.mycnhistore.com/us/en/newhollandag/self-repair-newhollandag?site=us&clear=true RE: Software for New Holland tractor - jmartin - 10-20-2023 Most CNH equipment uses EST. The protocol adapter is essentially a DPA5 with an additional diagnostic bus on it, maybe a K-line? I'm told a normal DPA5 can be opened up and an internal connection made which then makes it identical to the CNH DPA5, but I haven't verified this personally. CNH uses their own firmware in the DPA. Hope this helps. RE: Software for New Holland tractor - Colter - 02-14-2024 ..... RE: Software for New Holland tractor - protoraw - 02-24-2024 I remember sifting through various forums and articles to find a program compatible with my setup. I landed on a couple of user-friendly diagnostic programs that worked well with the specific make of my tractor. They offered clear instructions and good support, which made the process less of a headache. As for a recommendation, since you've used Jpro before, you might find that similar comprehensive diagnostic software could be more intuitive for you. I'd suggest looking into programs that are compatible with your current adapters and offer support for the T4050F model. If you hit a snag with parts or specific diesel-related diagnostics, this Kubota dealer near me has been mentioned for having knowledgeable folks who might offer some insight or even recommend a useful program. |
