| Cummins ISX15 2350 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cummins ISX15 2350 (/showthread.php?tid=9214) |
Cummins ISX15 2350 - SwampFox - 11-16-2023 Need some help with Fault Code 1867 PID 412 FMI 2 Exhaust Gas Recirculation Temp Data Erratic. We changed the EGR Temp Sensor out and still getting this. I did notice that the EGR Valve Acuator makes a buzzing noise for awhile when the truck is keyed on. RE: Cummins ISX15 2350 - Rawze - 11-16-2023 Register the engine on quickserv.com and look over the ecm wiring diagram. It might be something screwing with the +5volts supply to the sensor or a wire going bad somewhere. Also, make sure your replacement sensor is not after-garbage and that is came from a certified OEM. |
