Cummins ISL High pressure fuel pump interchange - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cummins ISL High pressure fuel pump interchange (/showthread.php?tid=9226) |
Cummins ISL High pressure fuel pump interchange - MOFIRE - 11-21-2023 I have a 2011 ISL high pressure fuel pump. It shows a part # FP90596-02. I have a 2016 ISL pump ,part # shows an FP92708-03. I need to know if they will interchange? RE: Cummins ISL High pressure fuel pump interchange - Rawze - 11-21-2023 Personally, I would not know the answer to that one. Myself, I have never taken a wrench to an ISL engine. Only have done programming for them. maybe someone else knows this answer. Why not just get the right part# and be done with it.. sell the incorrect one if you have it as a spare. |
