CECU3 and PLC Connection - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: CECU3 and PLC Connection (/showthread.php?tid=9248) |
CECU3 and PLC Connection - HeavyIndustry - 11-29-2023 Does anyone have any experience with Paccar ESA and configuring a CECU3 units to allow Can Bus communications to and from a PLC (programmable logic controller)? Looking to be able to read speeds, loads, pressures, and temps and write commands such as PTO engagement and rpm set points. RE: CECU3 and PLC Connection - Rawze - 11-29-2023 (11-29-2023 )HeavyIndustry Wrote: Does anyone have any experience with Paccar ESA and configuring a CECU3 units to allow Can Bus communications to and from a PLC (programmable logic controller)? Most cummins engines have a data-link control available on them for that type of application. Might want to contact them and get some info on it and how to program/control it. |
