| Can a bad primer pump put air in your fuel system - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Can a bad primer pump put air in your fuel system (/showthread.php?tid=9283) |
Can a bad primer pump put air in your fuel system - Nhramember - 12-14-2023 Hey I got another question can a bad primer pump get air in your fuel system. I’m just curious learning more about this isx 15 2350 everyday. Thanks Nate RE: Can a bad primer pump put air in your fuel system - Rawze - 12-14-2023 I would say highly unlikely, but not completely impossible. RE: Can a bad primer pump put air in your fuel system - NDISX15 - 12-14-2023 I would suspect worn/damaged fuel hoses long before I suspected a primer pump introducing air into the system. Even more likely would maybe be a bad sealing washer or two on the suction side banjo bolt to the pump. But even then....not completely impossible, not definitely not "common" in any sense. |
