2002 ISX cm570 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 2002 ISX cm570 (/showthread.php?tid=9354) |
2002 ISX cm570 - Caveman - 01-21-2024 Hello all! New to the forum. I searched the forum but couldn't find what I was looking for. I'm wondering what version of cummins insight I need to connect to my cm570 ecm? I have the pre-egr version with 475hp. RE: 2002 ISX cm570 - Signature620 - 01-22-2024 Any Insite version that has come out after the year 2000. All the easily obtainable versions will work with cm570 perfectly (7.6, 8.3, current version, etc) RE: 2002 ISX cm570 - Caveman - 01-22-2024 OK that's what I figured but just wanted to be sure. So once I get the inline 6 off of ebay or amazon I'll also need a laptop/computer correct? Does the inline 6 come with the software needed? I do have a Microsoft Surface Pro laptop. I wonder if that would work? Is it a USB connection? RE: 2002 ISX cm570 - Rawze - 01-22-2024 Inline adapters use a USB connection. RE: 2002 ISX cm570 - hhow55 - 01-23-2024 It would be a good idea to have a laptop that is only used for your insite. And be sure the virus software is not active. RE: 2002 ISX cm570 - Caveman - 01-23-2024 (01-23-2024 )hhow55 Wrote: It would be a good idea to have a laptop that is only used for your insite. And be sure the virus software is not active. What laptop do you all on the forum recommend? RE: 2002 ISX cm570 - Signature620 - 01-23-2024 Any windows laptop will be fine. There are no high end or unusual requirements for Insite. |
