I have a question about doing the bottom end. - Printable Version
+--- Thread: I have a question about doing the bottom end. (/showthread.php?tid=9420)
I have a question about doing the bottom end. - Nhramember - 02-16-2024
What is the best oil pump besides Cummins on the market? I know I can do oem but checking for rod bearings and main bearings since I just hit the 1 million mark on my 2015 kw t680. I wanted to get here and did now I wanna do a new oil pump and the bottom end. Thanks everyone
RE: I have a question about doing the bottom end. - Nilao - 02-16-2024
OEM only on internal parts. That is the only answer you will get from the reputable people here. That is one place you don't want to skimp. Something non-critical like a tensioner, belt, etc I would go with aftermaket.
RE: I have a question about doing the bottom end. - Pd6cas2 - 02-16-2024
Rawze will have a fun answering this :-)
Stop trying to save a nickel to spend a dollar later.
Replace oil pump OEM and Shim Correctly and make sure to double check of size bearing or mismatch.
RE: I have a question about doing the bottom end. - Rawze - 02-16-2024
(02-16-2024 )Pd6cas2 Wrote:  Rawze will have a fun answering this :-)
Replace oil pump OEM SHIM. Correctly and make sure to double check of size bearing or mismatch.
I could not have said it better myself..lol
