Cm871 code spn 2791 fmi 13 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cm871 code spn 2791 fmi 13 (/showthread.php?tid=945) |
Cm871 code spn 2791 fmi 13 - Qman - 09-28-2016 EGR VALVE CONTROLLER OUT OF COLIBRATION... DOES THE EGR VALVE HAVE TO BE REPLACED? RE: Cm871 code spn 2791 fmi 13 - Hammerhead - 09-28-2016 Unknown. Remove it, clean it thoroughly with carb cleaner, use some penetrating lubricant ONLY if required, while attempting to free it's movement, if it moves freely full travel after then no. Just clean out penetrating lubricant as the soot will love to stick to that, and reinstall. Test the actuator as well while removed to ensure it travels properly. If you can't free it's movement, or the spring is broken or damaged, then yes it must be replaced. RE: Cm871 code spn 2791 fmi 13 - Rawze - 09-29-2016 It can also be the delta-P sensor bad, or clogged crossover tubes. It can also be other problems/sensor issues that make the engine want more EGR than the valve can give. A thorough EGR tune-up and cleaning out the EGR valve and testing it is a good start. ======== It can also be the wrong software in your engine causing it if someone put a different HP setting (calibration) in. RE: Cm871 code spn 2791 fmi 13 - Qman - 09-30-2016 Thnks for the info,,,, |
