| 2014 cm2350 Prostar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: 2014 cm2350 Prostar (/showthread.php?tid=9509) |
2014 cm2350 Prostar - GoodWork - 03-29-2024 Hey guys I’m going thru some trouble with the starter relay fuse. It just clicks :/ but no crank. I saw some guy do a hack to bypass(years ago before having issue) it anyone know how to do it? Ty!!! RE: 2014 cm2350 Prostar - Rawze - 03-29-2024 how do you know its just the fuse and not the bendix wearing out?. RE: 2014 cm2350 Prostar - GoodWork - 03-29-2024 (03-29-2024 )Rawze Wrote: how do you know its just the fuse and not the bendix wearing out?. Sir I replaced the starter as soon as it started clicking, no luck sometimes it starts on the first try and sometimes on the 15th :( RE: 2014 cm2350 Prostar - Rawze - 03-30-2024 Simply bypassing a fuse is not a good idea without putting another fuse in its place to prevent an over-current condition, and the wiring harness burning the truck down if something shorts out. Are you sure it is not the clutch switch acting up and not allowing it to crank?. Maybe some history of the issue, better descriptions of when it started acting up, and what has been done so far?. Maybe this article helps... http://rawze.com/forums/showthread.php?tid=1514&pid=12861#pid12861 also, there is link to wiring diagrams for prostars at bottom of article too. |
