| Fuel restriction/leak down/high psi fuel related cummins tools - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Fuel restriction/leak down/high psi fuel related cummins tools (/showthread.php?tid=962) |
Fuel restriction/leak down/high psi fuel related cummins tools - joed2323 - 10-04-2016 Looking through cummins insite tests, I see they have tools for the high psi fuel pump test, high psi leak down test tool, fuel inlet restriction test tools. The leak down test requires 5 isolation fittings. My question is I priced these out from cummins and it comes out to be just over 1k in tools. These "tools" are basically just isolation type fittings. Does anyone know if they sell a kit somewhere with these fittings, might be cheaper then buying them individually from cummins, or can I find these fittings through a cheaper place?? I have insite but I do not have the proper tools to check the fuel system side RE: Fuel restriction/leak down/high psi fuel related cummins tools - Bigcam3cummins - 10-04-2016 If you are talking about fitting for checking fuel pressure and what not. Check out and hydraulic supply store or Amazon might have them too. Same with the gauges. RE: Fuel restriction/leak down/high psi fuel related cummins tools - Rawze - 10-05-2016 (10-04-2016 )joed2323 Wrote: Looking through cummins insite tests, I see they have tools for the high psi fuel pump test, high psi leak down test tool, fuel inlet restriction test tools. I would contact Mr. Hag here on the forum. He deals with a LOT of fuel system and pressure related problems on the ISX and is very good at it. He has made his own custom tools for it too. |
