| VERY SNAPPY CM870 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: VERY SNAPPY CM870 (/showthread.php?tid=9620) |
VERY SNAPPY CM870 - 3406E - 06-15-2024 Just started to test truck out and as you touch the throttle pedal it turns into a bounce about. I gotta start off in 3rd really slow and baby it to get somewhat of a decent take off. But the problem is really. Can it be adjusted, who where to get it done? I have insite but don’t have the calibrations yet. NEED YOUR HELP PLEASE. THANKS Canadian 9900 eagle 13speed 18913A Super 40 rears 3.73 gears RE: VERY SNAPPY CM870 - 3406E - 06-15-2024 (06-15-2024 )3406E Wrote: Just started to test truck out and as you touch the throttle pedal it turns into a bounce about. I gotta start off in 3rd really slow and baby it to get somewhat of a decent take off. But the problem is really. Can it be adjusted, who where to get it done? I have insite but don’t have the calibrations yet. NEED YOUR HELP PLEASE. THANKS 475 hp on the deck most like with a 1850 trq setting RE: VERY SNAPPY CM870 - Rawze - 06-15-2024 Accel pedal settings set incorrectly?. - Put the original 100% factory program that belongs to that engine and truck in it and see if it drives more normal. RE: VERY SNAPPY CM870 - 3406E - 06-15-2024 Thanks, is that only done by Cummins dealer? RE: VERY SNAPPY CM870 - 3406E - 06-15-2024 Hearing it can also be a problem of the accelerator pedal sensor gone bad. Or the harness for it to the ecm |
