Coolant level rising reservoir - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Coolant level rising reservoir (/showthread.php?tid=9628) |
Coolant level rising reservoir - Cumminx15 - 06-26-2024 My coolant level is rising all the way to the top in the reservoir when cold starting matter couple of minutes, Truck hasn’t been ran in a year just idling and driving around the block. Other issues that I’m having on the truck -I have an Air leak Also when after my tanks are full I come and check on it the next day the tanks are near almost zero. I’m thinking there’s an air to air leak in the system ?? - My air Fliter is making a rumbling noise when idling even when and after the air governor cut out Don’t know if it’s a turbo issue or air compressor ?? Maybe the intercooler is leaking air or the hoses feel loose I squeezed it the other day it made the noise worse - When I check the engine oil cap I feel it’s condensation water type greenish around the engine oil cap but when I drive the truck the next day it’s dry ?? And it comes back when the truck sits for weeks ? No codes or nothing 425k miles 8.5k engine hours Cummins x15 RE: Coolant level rising reservoir - Rawze - 06-27-2024 - What you describe about the coolant level going up after its cold and sits + greenish moisture on oil cap sounds like the tell tale signs of a liner dancing (head gasket) issue to me. more on this ...: http://rawze.com/forums/showthread.php?tid=9404&pid=79897#pid79897 |
