| Governed at 65 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Governed at 65 (/showthread.php?tid=9631) |
Governed at 65 - 3406E - 06-28-2024 Truck is governed at 65mph running @ 1500 rpm in the last gear. It’s a 13 speed 18913a. 3.73 ratio.Is ok to bump it up to about 75. I’m thinking if I do that the rpm will go up to like 1700? Thoughts? Thanks RE: Governed at 65 - Rawze - 06-28-2024 Its far better to turn off the gear down protection and run it in higher rpm ranges a gear or 2 down instead of trying to scream down the roads at 70+. RE: Governed at 65 - 3406E - 06-29-2024 Gear down protection, what’s that exactly? Didn’t quite get a hook of what your saying. RE: Governed at 65 - Rawze - 06-29-2024 (06-29-2024 )3406E Wrote: Gear down protection, what’s that exactly? Didn’t quite get a hook of what your saying. The GD protection option makes it to where you cannot rev engine past 1500 rpm when its not in top gear. RE: Governed at 65 - 3406E - 06-30-2024 (06-29-2024 )Rawze Wrote:(06-29-2024 )3406E Wrote: Gear down protection, what’s that exactly? Didn’t quite get a hook of what your saying. Got it |
