| Whining noise CM2250 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Whining noise CM2250 (/showthread.php?tid=9634) |
Whining noise CM2250 - Atlas - 07-01-2024 have a 2011 cascadia with a CM2250 engine. I hear a low sounding moan or whining noise coming from driver side of engine, especially above 1000 rpm. I took my stethoscope and pinpointed noise at its loudest directly behind fuel filter from the fuel filter head/ ECM cooling plate. I wrapped a fuel line with fuel line hose where it attached to plate with new clamp. No difference. Installed new fuel pump over 2 years ago. Any thoughts ? RE: Whining noise CM2250 - tree98 - 07-01-2024 How many miles are on it and when was the high pressure pump rebuilt last? RE: Whining noise CM2250 - SquareOne - 07-01-2024 Is it intermittent? Does it occur only in the lower RPM ranges (then abruptly go away), or after a fuel filter replacement? Is it a whine or more of a harmonic hum? If the above info sounds like your issue, I believe it has something to do with the fuel lines and banjo fittings (wear possibly, but can't remember for sure). There was an updated fuel line which needs to be installed with the newer revision of the high pressure fuel pump. Not sure if you completed that the last time the internals were replaced, but it may be a good idea to find out. RE: Whining noise CM2250 - JimT - 07-03-2024 SquareOne: I believe the updated fuel line you are referring to is not something you can overlook or forget to change. One pump had the line connect to the underside of the actuator while the other pump connects on the top of the actuator. The line needed is completely dependent on the version of the pump. RE: Whining noise CM2250 - SquareOne - 07-03-2024 (07-03-2024 )JimT Wrote: SquareOne: I believe the updated fuel line you are referring to is not something you can overlook or forget to change. One pump had the line connect to the underside of the actuator while the other pump connects on the top of the actuator. The line needed is completely dependent on the version of the pump. Yep, that jogged my memory from back when I replaced my low side of the high pressure pump. You are correct....that's exactly what it was. Thanks for clarifying. |
