International 9900 ac - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: International 9900 ac (/showthread.php?tid=9659) Pages: 1 2 |
International 9900 ac - 3406E - 08-03-2024 What could cause only my bunk to be blowing cold. I put a brand new compressor 3 weeks ago. Vacuumed and gassed over. It was blowing cold the first two days but now only bunk is cool. Thanks. Can’t wait till winter RE: International 9900 ac - Rawze - 08-03-2024 blend doors acting up?. RE: International 9900 ac - 3406E - 08-03-2024 (08-03-2024 )Rawze Wrote: blend doors acting up?. Yh my uncle just told me the same thing, never knew of them. Was told to spray it with wd40 or buy new ones. Thanks RE: International 9900 ac - Yauchout - 08-03-2024 (08-03-2024 )3406E Wrote:(08-03-2024 )Rawze Wrote: blend doors acting up?. Depending on the year, WD-40 might be a waste of your time. If it's newer and has plastic blend doors, they're not going to be seized and you wouldn't need the entire blend door, likely just the actuator RE: International 9900 ac - 3406E - 08-04-2024 (08-03-2024 )Yauchout Wrote:Yes this is true my doesn’t have the rods(08-03-2024 )3406E Wrote:(08-03-2024 )Rawze Wrote: blend doors acting up?. RE: International 9900 ac - 3406E - 08-04-2024 Think I might just purchase two of the Oem. Can get them around 80 a peice. RE: International 9900 ac - Rawze - 08-04-2024 (08-04-2024 )3406E Wrote: Think I might just purchase two of the Oem. Can get them around 80 a peice. 80 bucks sounds over-priced to me. Isn't this the same blend door for $16.00? .. or am I missing something? ref: https://amzn.to/3yrjub6 RE: International 9900 ac - 3406E - 08-04-2024 Well one has a rod to correct RE: International 9900 ac - 3406E - 08-04-2024 (08-04-2024 )Rawze Wrote:(08-04-2024 )3406E Wrote: Think I might just purchase two of the Oem. Can get them around 80 a peice. I think because I was looking at oem. But I found a leak couple minutes ago on my ac condenser line. Guess that’s why the module won’t open the door, so if I’m guessing the module is good |
