Dpf temp - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Dpf temp (/showthread.php?tid=9694) |
Dpf temp - Dididadzz - 08-26-2024 Hey Boss am trying to do a regen but the temp is staying at 260 then walk back down to 240 an idle down a little bit can’t quite figure it out anyone had this issue ?[attachment=9562][attachment=9562] RE: Dpf temp - tree98 - 08-26-2024 Will it pass a fuel rail leak down test using insite? RE: Dpf temp - Dididadzz - 08-27-2024 (08-26-2024 )tree98 Wrote: Will it pass a fuel rail leak down test using insite? It saying am having fuel delivery problem data valid but below normal operating moderate to severe. I have insight I was looking into doing a leak test but it seems I have to have the injector out is that correct? How do I do a leak test ? RE: Dpf temp - tree98 - 08-27-2024 No you don't take anything apart. https://rawze.com/forums/showthread.php?pid=76979 RE: Dpf temp - hhow55 - 08-27-2024 Do you have an cm871 engine? RE: Dpf temp - tree98 - 08-27-2024 (08-27-2024 )hhow55 Wrote: Do you have an cm871 engine? Ha ha yea he does, I see it on the top of his insite screen. Well forget about the leakdown test, it doesn't apply to your engine. I have common rails on the brain, that's about all I see anymore. Have you checked for exhaust leaks? How old is your dosing injector? RE: Dpf temp - hhow55 - 08-27-2024 When was last egr tuneup done? Is the hood down when doing a regen? RE: Dpf temp - Rawze - 08-28-2024 Has anyone performed an EGR tune-up on it first?. If the engine is not running well, sensors clogged with soot, or the egr is clogged etc.. then it will not regen properly either. ref: https://rawze.com/forums/showthread.php?tid=7&pid=9#pid9 also, maybe these help... Injector leak test for CM871... ref: https://rawze.com/forums/showthread.php?tid=7747&pid=67948#pid67948 DPF regen video for 871... ref: https://rawze.com/forums/showthread.php?tid=8724&pid=75446#pid75446 |
