| High sodium in oil - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: High sodium in oil (/showthread.php?tid=971) |
High sodium in oil - sbtrucking - 10-07-2016 [attachment=2058]Rotela triple with galon of 85 140 supertech gear oil Is this high sodium level bad? RE: High sodium in oil - snailexpress - 10-07-2016 SPEEDCO? Never trust them. Take another sample to CAT or any reputable lab. See the difference/ RE: High sodium in oil - hhow55 - 10-07-2016 What kind of motor do you have?. Need more engine info. RE: High sodium in oil - simon999 - 10-07-2016 Actually I did couple times oil samples at speedco and they are close to the other labs. You can resample with polaris or blackstone to make sure. This sample shows coolant in the oil. Its not critical, but cummins says if its more than 50ppm in can start to cause bearings corrosion. You should notice if you losing some coolant Pressure test your coolant, egr cooler. Might be many things like air compressor head, cylinder head, head gasket, dropped liners.. When I had this problem was oil cooler gasket between engine block and oil cooler housing mixing oil and coolant. RE: High sodium in oil - sbtrucking - 10-08-2016 Engine cm2250 The truck has not lost colant at all, When we flushed the engine after the ceramic plungers broke i decided to change the oil cooler, for some reason the oil cooler gasket didnt seal properly and on the first start up had oil in the colant and coolant in the oil, We did change the oil twice and installed a new maintenance free breather filter. So I am guessing that why there is still some coolant in the sample, i will test it again next oil change Godwilling |
