Voltage to magic plug - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Voltage to magic plug (/showthread.php?tid=9711) |
Voltage to magic plug - mxmom777 - 09-07-2024 What should the voltage be at the magic plug ? 5 or less ? Thanks RE: Voltage to magic plug - Rawze - 09-07-2024 The supply voltages to all of the sensors on the engine are +5 volts. Register your engine ser# on quickserv.com and you can get access to the ECM wiring diagram .. where it will answer those kinds of questions. |
