| Calterm 3.17 using inline 6 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Calterm 3.17 using inline 6 (/showthread.php?tid=9771) |
Calterm 3.17 using inline 6 - SunnySide - 10-13-2024 I'm not able to connect to 3.17 for the first time and I'm thinking it's because I'm using an online 6. The reconnect and reset data link boxes towards the top are greyed out. I connect with insite fine. RE: Calterm 3.17 using inline 6 - Rawze - 10-13-2024 should work fine with an inline6. Go to CT datalink settings and ensure its set up properly as an option. RE: Calterm 3.17 using inline 6 - SunnySide - 10-13-2024 Thanks. I'll give that a shot. |
