| Learning to pull my file. - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Learning to pull my file. (/showthread.php?tid=9811) |
Learning to pull my file. - wadeclaiborne - 11-07-2024 Hello and thanks for letting me in. 2015 Kenworth demandated... this truck was already done when I purchased it so I'm not exactly sure what has been done tune wise other than its supposedly set at 550. I do believe it is always in warmup mode at an idle from what I'm used to on other trucks. I'm not sure the procedure and or what exactly is needed to pull the file for a proper review. Software? Proper cables and so on. Thanks for any help. RE: Learning to pull my file. - Lunchtime92 - 11-07-2024 (11-07-2024 )wadeclaiborne Wrote: Hello and thanks for letting me in. 2015 Kenworth demandated... this truck was already done when I purchased it so I'm not exactly sure what has been done tune wise other than its supposedly set at 550. I do believe it is always in warmup mode at an idle from what I'm used to on other trucks. I'm not sure the procedure and or what exactly is needed to pull the file for a proper review. Software? Proper cables and so on. Thanks for any help. Take a look here... https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945 RE: Learning to pull my file. - Rawze - 11-07-2024 maybe this helps... ref: http://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945 RE: Learning to pull my file. - wadeclaiborne - 11-08-2024 Great info! Where can one obtain the calterm software? I've searched around a bit but just not quite sure where to look. Feel free to pm me if you'd rather not just throw it out there. RE: Learning to pull my file. - Lunchtime92 - 11-08-2024 (11-08-2024 )wadeclaiborne Wrote: Great info! Where can one obtain the calterm software? I've searched around a bit but just not quite sure where to look. Feel free to pm me if you'd rather not just throw it out there.Pm sent |
