| Maximum DPF Soot Load - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Maximum DPF Soot Load (/showthread.php?tid=982) |
Maximum DPF Soot Load - Smacklin - 10-08-2016 I'm considering buying a Peterbilt 2013 587 with a cummins engine soon. I got a ECM print out what concerns me under the maximum DPF Soot load says Above normal - least severe. Can anyone explain this to me. Should I get the filter cleaned before purchase? RE: Maximum DPF Soot Load - Hammerhead - 10-08-2016 Post the report. Post the "Regen History". You also want the "Engine Abuse History" report as well. If you haven't, pop the rocker/valve cover and post pics of the cams and rollers as well for the most detailed honest assessment. RE: Maximum DPF Soot Load - Smacklin - 10-08-2016 (10-08-2016 )Hammerhead Wrote: Post the report.Ok thanks |
