| 2005 14L Series 60 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: 2005 14L Series 60 (/showthread.php?tid=9823) |
2005 14L Series 60 - TomHanson - 11-18-2024 Engine runs rough. In the past 4 months, I've replaced #1 and #3 injectors two separate times. This would instantly fix the rough idle, and cure my "injector #1 response time long" fault code. Now, the same issue is happening. Went through all ecm data to find fuel temp and ambient air temp show -40 degrees f, which were the only odd things I could see. Truck came in this time with a plethora of inactive faults, and 3 active for injector 1 - response time long, fuel temp sensor - input voltage low, and oil pressure high. I'm leaning towards something in the harness at this point, I was curious is someone could get me some troubleshooting trees for these to at least point me somewhere? Or give me some input on some things to check... RE: 2005 14L Series 60 - Mal4shtf - 11-18-2024 First thing. Individually load test each battery. Inspect and clean all battery and starter connectors. Inspect cable to starter and alternator for rubbing. |
