| Isx15 oil in coolant - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx15 oil in coolant (/showthread.php?tid=9827) |
Isx15 oil in coolant - Kiko - 11-21-2024 Hello all. I am having trouble with my Isx15 cm2350. I have oil in coolant. Trans cooler changed a year ago along with engine oil cooler. All was good untill lately and have oil in my coolant again. No pressure to n rad and no coolant in oil. Did a 20 psi pressure test on rad and after fixing some external leaks it will drop pressure after sitting. Removed oil filter and no coolant drops noticed. Removed turbo drain line and no coolant loss noticed. So a couple of questions. If it is engine oil cooler can I see coolant coming from it if I remove oil pan. Also has anyone seen a compressor create this problem without it pressurizing the rad. When running I am having no coolant loss from reservoir. RE: Isx15 oil in coolant - Rawze - 11-21-2024 Oil in coolant is almost guaranteed to be a problem with the oil cooler for the engine. It is about the only place where pressurized oil meets up with coolant so closely together from within the same component. When the tranny cooler goes bad, it usually fills the tranny with coolant instead of the other way around. RE: Isx15 oil in coolant - Kiko - 11-21-2024 Is there a way to test that cooler without taking it off and tank testing it. RE: Isx15 oil in coolant - Rawze - 11-21-2024 (11-21-2024 )Kiko Wrote: Is there a way to test that cooler without taking it off and tank testing it. you can drop the oil pan and remove the oil filter + let it sit over night with 20 psi coolant pressure on the system. .. see if coolant is seeping out of the oil pump or filter opening, or other places. RE: Isx15 oil in coolant - Kiko - 11-21-2024 Thanks Rawze. I appreciate your help. Will try that and let you know. RE: Isx15 oil in coolant - Kiko - 12-24-2024 Hello again. Thought I would post that the problem was the trans cooler again. Removed from system and all is good. Will be putting in a new one when it shows up. RE: Isx15 oil in coolant - Rawze - 12-24-2024 (12-24-2024 )Kiko Wrote: Hello again. Thought I would post that the problem was the trans cooler again. Removed from system and all is good. Will be putting in a new one when it shows up. Replace that trans cooler with an external air cooled unit. ref: http://rawze.com/forums/showthread.php?tid=3217&pid=28933#pid28933 |
