valve seat ring - Printable Version
+--- Thread: valve seat ring (/showthread.php?tid=9833)
valve seat ring - ktblogistics - Yesterday
it is 6.7 isb cummins and truck had bad valve seat ring on cylinder 3, head has been replaced and after 3k miles same thing happened on cylinder 4 , any thoughts on this ? truck is demandeted,(new head from cummins) not reman
RE: valve seat ring - ktblogistics - Yesterday
pictures
RE: valve seat ring - tree98 - Yesterday
Who did the demandate? Does it still have the VG turbo on it? Can you post a pic of the tops of the pistons?
RE: valve seat ring - Rawze - Yesterday
(Yesterday )ktblogistics Wrote:  it is 6.7 isb cummins and truck had bad valve seat ring on cylinder 3, head has been replaced and after 3k miles same thing happened on cylinder 4 , any thoughts on this ? truck is demandeted,(new head from cummins) not reman
take your pick...
== Exhaust wet-stacking can cause valve seat(s) to loosen.
== A Fuel source introduced into the cylinder when it is not supposed to be (leaky injector, leaking valve stem, oil or fuel getting into the intake, etc).
== excessive cylinder/manifold pressures can cause it (bad programming and/or excessive boost all the time). Is it known to have a turbo cough (a whoof, whoof, whoof sound under the hood) when you get on it hard or let off the full throttle suddenly?.
== Uneven head heating/overheating.
- See the scoring and odd coloring vs the other cylinders around the intake valve(s)?. Looks to me like Fuel (or something) is getting into that cylinder when it should not be.
Did it pass a rail leak test after the rebuild??...
ref: http://rawze.com/forums/showthread.php?tid=8728&pid=75483#pid75483
Its also de-mandated, so if I have not reviewed the programming, then that is the next step as well.
