| Take a look at my alignment report...was it bad? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Take a look at my alignment report...was it bad? (/showthread.php?tid=986) |
Take a look at my alignment report...was it bad? - preacherboy24 - 10-08-2016 I dont remember my alignment being off this bad. He said everything was fine...kingpins...ect. I was rubbing the drivers side outer rib pretty good. Any ideas on how this could have affected my fuel mileage? RE: Take a look at my alignment report...was it bad? - Nilao - 10-08-2016 i doubt it had a big impact on mpgs. Maybe a tenth. But as Rawze would have asked them. "What is the allowable tolerances on the kingpins? Did you measure them?" Same with the tie rod ends. RE: Take a look at my alignment report...was it bad? - snailexpress - 10-09-2016 (10-08-2016 )preacherboy24 Wrote: I dont remember my alignment being off this bad. He said everything was fine...kingpins...ect. I was rubbing the drivers side outer rib pretty good.Computerized alignment as good as alignment technician is. Was he follow the procedure without shortcuts or hurry to get next customer. High end equipment is only a tool in mechanic's hands. I'll bet he didn't check is steer axle is 90 degree to the truck frame. He didn't lift truck frame to check front spring pins. If not all his job is BS. RE: Take a look at my alignment report...was it bad? - snailexpress - 10-09-2016 Check page 118. RE: Take a look at my alignment report...was it bad? - Hedley - 10-09-2016 Most problems with premature wear on steer tires comes from the rear tandems being misaligned, alway do all three axles. |
