CM870 gear fuel pump rebuild - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: CM870 gear fuel pump rebuild (/showthread.php?tid=9864) |
CM870 gear fuel pump rebuild - 907leverman - 12-16-2024 Does anyone know of any rebuild kits for fuel pump 4088847? I replaced mine without having to give up a core and would love to have one to keep on the shelf for my other trucks. Any information on it would be great! RE: CM870 gear fuel pump rebuild - tree98 - 12-17-2024 Even if you could get one I wouldn't suggest rebuilding it. If its not done right or the parts let loose, you'll take out all your injectors. Thats the kind of thing we call stepping over a dollar to save a penny. Throw it away and move on. |
