Turbo he551v - Printable Version
+--- Thread: Turbo he551v (/showthread.php?tid=9886)
Turbo he551v - Upnorth83 - 01-02-2025
Can I change the compressor wheel on my turbo without issue?? I know that there are balanced. I screwed up. My compressor housing clamp broke. So I was taking the compressor housing off to get the clamp off, I let the housing slip and I damaged three blades. I’m just wondering if I can safely replace the wheel on my own without sending turbo off. Or if I’m in for a turbo replacement because of my carelessness and stupidity.
RE: Cm870 turbo he551v - tree98 - 01-02-2025
Nope you can't fix that yourself. They are balanced at extremely high speeds. You need very specialized equipment and knowledge to do such things.
RE: Turbo he551v - Upnorth83 - 01-02-2025
Ya know that’s what I figured. But I just thought I’d ask. I’ve been beating myself up All day and night for this mistake. Thank you for your reply. I knew better was just looking for an out.
