| Brass shavings in the oil pan - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Brass shavings in the oil pan (/showthread.php?tid=9893) |
Brass shavings in the oil pan - Samvelm83 - 01-08-2025 What can cause brass shavings in the oil pan? (mains and rods excluded) RE: Brass shavings in the oil pan - Rawze - 01-08-2025 bearings in the head... or wrist pin bushings. RE: Brass shavings in the oil pan - Samvelm83 - 01-08-2025 (01-08-2025 )Rawze Wrote: bearings in the head... or wrist pin bushings. Are wrist pins made of brass? RE: Brass shavings in the oil pan - Rawze - 01-09-2025 (01-08-2025 )Samvelm83 Wrote:(01-08-2025 )Rawze Wrote: bearings in the head... or wrist pin bushings. yes, the bushings are, and if they wear too much, it will send a piston thru the block without warning. RE: Brass shavings in the oil pan - Samvelm83 - 01-09-2025 (01-09-2025 )Rawze Wrote:(01-08-2025 )Samvelm83 Wrote:(01-08-2025 )Rawze Wrote: bearings in the head... or wrist pin bushings. What symptoms will the engine have in this case? Currently has no issues RE: Brass shavings in the oil pan - tree98 - 01-09-2025 Can you post pics of these "shavings" ? RE: Brass shavings in the oil pan - Samvelm83 - 01-09-2025 (01-09-2025 )tree98 Wrote: Can you post pics of these "shavings" ? Unfortunately I don't have it RE: Brass shavings in the oil pan - Rawze - 01-09-2025 (01-09-2025 )Samvelm83 Wrote: ... wrist pin failures give zero warning. |
