| CM 870 Smoking white - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM 870 Smoking white (/showthread.php?tid=9904) |
CM 870 Smoking white - Ken Worth - 01-16-2025 Hello guys my cm 870 started smoking white smoke and what feels like sputtering when reving up. But If I take off and start driving the smoke stops and truck is normal/ no power loss , or if I raise the ideal up to 1100-1200 and hold it there it will smoke for a little and then clear out to normal no smoke no sputtering nothing. Any ideas what could be causing this? Thanks guys So far I changed fuel filters. RE: CM 870 Smoking white - tree98 - 01-16-2025 Is it using coolant? Could be the head gasket..... dropped liner?. RE: CM 870 Smoking white - Rawze - 01-16-2025 also do injector leak tests on it too.. ref: http://rawze.com/forums/showthread.php?tid=7747&pid=67948#pid67948 RE: CM 870 Smoking white - Ken Worth - 01-25-2025 (01-16-2025 )tree98 Wrote: Is it using coolant? Could be the head gasket..... dropped liner?. Not using coolant or anything. Uses some oil but it has front main leaking like most Cummins RE: CM 870 Smoking white - Ken Worth - 01-25-2025 (01-16-2025 )Rawze Wrote: also do injector leak tests on it too.. Am still waiting on the adapter to do a leak test. But I was Abel to get a cylinder cutout test and turning off number 4 it stops smoking. Turing of the front 3 causes to smoke even more. Or turning of back 3 it also stops. I was scared to try and run it on one at a time. Could this indicate number 4 injector leaking? Thanks for the reply’s guys. RE: CM 870 Smoking white - tree98 - 01-25-2025 Yea seems to be something going on with #4 You can run it on 1 cylinder, won't hurt it at all. RE: CM 870 Smoking white - Ken Worth - 01-25-2025 (01-25-2025 )tree98 Wrote: Yea seems to be something going on with #4 Amazon finally delivered the adapter for the leak test and I jumped on it real quick. When I mount it on the rear fueling actuator (back of the engine) there is 0 bubbles. But when I mount it on the front one it has crazy big bubbles. Would This mean it’s one or all of the front 3 injectors right? On the cm870 there is 4 actuators, the very first one is fueling for the front 3 and the very last 4th in line, is for the rear 3 right? Or have I miss read the instructions on test procedure. I was not abel to bar it by hand to see if it between A B or C because my damper markings are missing/and it got dark out side. I will do that tomorrow after finding the correct markings on the damper. RE: CM 870 Smoking white - tree98 - 01-26-2025 (01-25-2025 )Ken Worth Wrote: When I mount it on the rear fueling actuator (back of the engine) there is 0 bubbles. But when I mount it on the front one it has crazy big bubbles. Yes (01-25-2025 )Ken Worth Wrote: On the cm870 there is 4 actuators, the very first one is fueling for the front 3 and the very last 4th in line, is for the rear 3 right? Yes....... it's possible you have a bad timing or metering actuator for the back 3 since you've found an issue on #4 but no bubbles. Also look VERY close when barring the engine over, "bubbles" can be easy to miss. Watch Rawze's video(3 short videos) and you'll see what i mean. https://youtu.be/Wu_WN8BA-LA?si=atQphHcIJ6w-xbb6 RE: CM 870 Smoking white - Ken Worth - 01-26-2025 (01-26-2025 )tree98 Wrote:(01-25-2025 )Ken Worth Wrote: When I mount it on the rear fueling actuator (back of the engine) there is 0 bubbles. But when I mount it on the front one it has crazy big bubbles. Thanks to Rawze and his videos is the only reason am even messing with any of this. What do you guys think is this too much oil on turbo side feels caked up little wet. |
