| Need help with CM 870 & CM 871 programming, non VGT. Please - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Need help with CM 870 & CM 871 programming, non VGT. Please (/showthread.php?tid=9922) |
Need help with CM 870 & CM 871 programming, non VGT. Please - DieselKing - 01-22-2025 Hello, I need someone to help me program CM 870 and CM 871. They are non- VGT engines and CM 871 has complaints about low boost and high fuel economy. Please let me know if anyone can help, really in a pinch! RE: Need help with CM 870 & CM 871 programming, non VGT. Please - Rawze - 01-22-2025 yeah ... start by putting back the VGT turbo on each of them and undo those horrible redneck engine killing mods to them. and yeah... the programming is bad as well if someone did that trash to them. RE: Need help with CM 870 & CM 871 programming, non VGT. Please - DieselKing - 01-22-2025 (01-22-2025 )Rawze Wrote: yeah ... start by putting back the VGT turbo on each of them and undo those horrible redneck engine killing mods to them. Yup...If no one wants to touch it then might have to send the guys on their way. RE: Need help with CM 870 & CM 871 programming, non VGT. Please - DieselKing - 01-22-2025 Thing is I just did the heads on both of them, if the programming doesn't get fixed then they are coming back soon, just trying to prolong that for a bit. RE: Need help with CM 870 & CM 871 programming, non VGT. Please - Aleeex - 01-22-2025 I have been dealing with a lot of this BS. The internet said its ok, must be good then. RE: Need help with CM 870 & CM 871 programming, non VGT. Please - DieselKing - 01-22-2025 (01-22-2025 )Aleeex Wrote: I have been dealing with a lot of this BS. The internet said its ok, must be good then. Everyone around here keeps telling drivers oh yeah take your VGT off that's causing all the problems! So far I have worked on only one 870/871 that still has VGT on. Just putting it together right now. When you tell people that VGT is good , they are just shellshocked! {part of post removed} RE: Need help with CM 870 & CM 871 programming, non VGT. Please - tree98 - 01-22-2025 You can't make these engines run right with a non VGT. You'll have to put them back on if you want the programming to be corrected. How is someone going to adjust F/A ratio if the ECM no longer has any control over the very thing that sets the F/A ratio?? RE: Need help with CM 870 & CM 871 programming, non VGT. Please - tree98 - 01-22-2025 Send a message to runningrough, he's good with the 870's. They are a fickle beast. https://rawze.com/forums/member.php?action=profile&uid=993 RE: Need help with CM 870 & CM 871 programming, non VGT. Please - DieselKing - 01-22-2025 (01-22-2025 )tree98 Wrote: Send a message to runningrough, he's good with the 870's. They are a fickle beast. I tried, but he must have been busy. He didn't reply yet, but thanks for the info! |
