| ISX 15 code spn 641 fmi 11 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: ISX 15 code spn 641 fmi 11 (/showthread.php?tid=9934) |
ISX 15 code spn 641 fmi 11 - farmtrucknw - 01-30-2025 Have a 2016 Prostar with ISX 15 400ST, bone stock and have been getting this code thrown erratically lately. Truck seems to run fine and when it throws I will get the triangle on the dash warning engine light. Cycle the key and it goes away. What do I need to be looking for on this? Turbo actuator on the way out or spotty connection on the actuator harness? Truck has 492k miles on it. Thanks. RE: ISX 15 code spn 641 fmi 11 - tree98 - 01-30-2025 What is the actual code shown in insite? RE: ISX 15 code spn 641 fmi 11 - farmtrucknw - 01-30-2025 I don't have insite, that was the pushing the cruise control on and resume button together. I thought I could pull them off with efi live and HD autocal but I could not. I have a neighbor that has insite if I need to have him do it. RE: ISX 15 code spn 641 fmi 11 - tree98 - 01-30-2025 Yea you need to get the actual code. RE: ISX 15 code spn 641 fmi 11 - Rawze - 01-30-2025 spn641, fmi11 = I think that is Fault Code '2198'. VGT actuator root cause unknown. Do a turbo inspection, re-calibrate it, etc. Is this engine de-mandated (deleted)... if so then copy the program from the ecm and e-mail it to me for a review so that you know its not tearing up the turbo. |
