2012 KW t800 outside air temperature sensor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: 2012 KW t800 outside air temperature sensor (/showthread.php?tid=9937) |
2012 KW t800 outside air temperature sensor - Auburn200x - 01-31-2025 So like the title says, the outside air temperature sensor on my T800 has been cut off by accident. The orginal motomirror had been replaced long ago and wanted at least a heated mirror installed. The sensor is the one in the harness, not the bottom of the mirror. Still have the sensor and was wondering if it can be spliced back in, if so what color is the words for it. If not is there a cost effective option to get another aftermarket sensor for it? Not super important, I just mainly don't like seeing the hash marks. RE: 2012 KW t800 outside air temperature sensor - J_Rok - 01-31-2025 (01-31-2025 )Auburn200x Wrote: So like the title says, the outside air temperature sensor on my T800 has been cut off by accident. The orginal motomirror had been replaced long ago and wanted at least a heated mirror installed. The sensor is the one in the harness, not the bottom of the mirror. Still have the sensor and was wondering if it can be spliced back in, if so what color is the words for it. If not is there a cost effective option to get another aftermarket sensor for it? Not super important, I just mainly don't like seeing the hash marks. Hello, if it’s a grey rectangular bulge in your mirror wiring harness it should be the same as mine and when I spliced in a new sensor the wires were light blue and yellow, that was a 2012 Peterbilt. Hopefully you can use your old one because last time I priced the sensor it was $$$ |
