| Chinese inline adapter install help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Chinese inline adapter install help (/showthread.php?tid=9953) |
Chinese inline adapter install help - arc1transport - 02-08-2025 So I purchased the inline 6 adapter with 8.7 on windows 10. After finally getting everything installed, I opened insite and brought me to home screen where you can connect to ECM, etc. this morning, I take it over to the truck, open insite and it's asking me to install or add a license. Any help would be greatly appreciated! RE: Chinese inline adapter install help - Rawze - 02-09-2025 the seller of those products usually helps with the licensing. Otherwise, maybe you get lucky and someone who knows what to do with it can PM you, or you can find an alternative working solution somewhere on the interwebs. RE: Chinese inline adapter install help - Bengy88 - 02-10-2025 For those that don’t know…. When you open the newer insites like 8.7, 8.8, and 8.9 that are found on the websites we all know of, once a day it will give you a licensing message ALWAYS click run in simulator. It will work as it is supposed to. RE: Chinese inline adapter install help - arc1transport - 02-11-2025 Thanks for the info! I got lucky and got a PM with a wealth of knowledge! |
