| Increasing HorsePower -- What You Need To Know |
| 07-16-2024, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #163 | |||
| RE: Increasing HorsePower -- What You Need To Know I'll have a go... I have a 2009 cm871 in a T800 I recently purchased, will be overhauling the engine due to worn out cams and age. Once that's finished Looking for a stronger calibration without smart torque feature. Engine #79370257 485ST AV10241 CPL 3749 Truck has 10 speed and 3.55 gear, Engine is still equipped with and using everything it came with. | |||
| 07-17-2024, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #164 | |||
RE: Increasing HorsePower -- What You Need To Know (07-16-2024 )RedBandit Wrote: I'll have a go... I have a 2009 cm871 in a T800 I recently purchased, will be overhauling the engine due to worn out cams and age. Once that's finished Looking for a stronger calibration without smart torque feature. Engine #79370257 485ST AV10241 CPL 3749 Truck has 10 speed and 3.55 gear, Engine is still equipped with and using everything it came with. Yours is listed in the first post of the thread here. AV10241 is simply the updated DPF version of program AV10048 (CPL2733). These are interchangeable with each other ... Code: ===========================The conversion chart for the updated CPL's and newer DPF's is listed here by the way: https://rawze.com/forums/showthread.php?...01#pid4001 I.E.> program AV10165 crosses over to program AV10248. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-18-2024, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #165 | |||
| RE: Increasing HorsePower -- What You Need To Know Thanks for the help! | |||
| 06-17-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #166 | |||
| RE: Increasing HorsePower -- What You Need To Know Looking at the list i cannot find my Cal is there one for a increase cal for AV10041. If there is i know i cant just upload it and run it i have special needs. | |||
| 07-24-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #167 | |||
| RE: Increasing HorsePower -- What You Need To Know I am wondering if a safe increase can be achieved for ESN#79985487 ECM code:HD10037 cpl 4342. | |||
| 07-24-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #168 | |||
RE: Increasing HorsePower -- What You Need To Know (07-24-2025 )riyln Wrote: I am wondering if a safe increase can be achieved for ESN#79985487 ECM code:HD10037 that is the highest trq available for that CPL. A custom program would be the proper way to adjust it beyond that... Some HP tweak, maybe .. but I would not recommend turning up the torque any more than it is. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-30-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #169 | |||
| RE: Increasing HorsePower -- What You Need To Know Hi I have a cm871 Esn 79332034 Cpl 2919 Ecm code av10277, original av10105 525/1850 I would like to change to a 575 or 600 hp with 1850 t Which code would be compatable, I can't seem to find anywhere where that number has been posted. Thanks | |||
| 07-31-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #170 | |||
RE: Increasing HorsePower -- What You Need To Know (07-30-2025 )spreader1 Wrote: Hi is the engine de-mandated (deleted)?. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-31-2025, (Subject: Increasing HorsePower -- What You Need To Know ) Post: #171 | |||
RE: Increasing HorsePower -- What You Need To Know (07-31-2025 )Rawze Wrote:(07-30-2025 )spreader1 Wrote: Hi No, it is not yet, plan to do that at some point, tho | |||
