2013 ISX 15 rapid sudden coolant consumption
Today, (Subject: 2013 ISX 15 rapid sudden coolant consumption )
RE: 2013 ISX 15 rapid sudden coolant consumption
(Yesterday )Nerv Wrote:  Here is #1 and #2 liner they both had 0.032 im guessing oem brass shims. When they were removed both shims were broken. Im guessing this block was never counterbored. Im getting a measurement of 4.688 with a regular depth micrometer, i need to be at 4.752 with a 0.032 shim. That is just using the one that comes with the new liners correct?
here is how it should be done. Anything less and you will not get a million miles out of it...
ref: https://rawze.com/forums/showthread.php?...6#pid70606
and as far as the liner heights go...
ref: https://rawze.com/forums/showthread.php?...9#pid28349
Also... those look like the shims that come with new style liners, and not some 'added' shims due to counter-boring. Be sure to verify and double-check your heights.
