| Cm871 RPM shut off |
| 01-25-2026, (Subject: Cm871 RPM shut off ) Post: #10 | |||
| RE: Cm871 RPM shut off Yh, that’s good help. He bought the a brand new computer yesterday and sent me a picture,he just need to get it programmed now. He was running the hefty 2050 trq before but he pulls heavy loads. | |||
| 01-25-2026, (Subject: Cm871 RPM shut off ) Post: #11 | |||
| RE: Cm871 RPM shut off Pay the few extra bucks and have dealer program ecm without truck first, if ecm is dead on arrival then you have bunch of hassle yourself. | |||
| 01-25-2026, (Subject: Cm871 RPM shut off ) Post: #12 | |||
| RE: Cm871 RPM shut off I’ll let him know, thanks. I thought it was just a simple case of putting a file on it. Egr is deleted, still running vgt. | |||
| 01-25-2026, (Subject: Cm871 RPM shut off ) Post: #13 | |||
RE: Cm871 RPM shut off (01-25-2026 )3406E Wrote: I’ll let him know, thanks. I thought it was just a simple case of putting a file on it. Egr is deleted, still running vgt. Keep your fingers crossed that it will be that easy, but mikkhh is right. If he hasn't opened the box yet I would take it to a dealer and have it bench flashed with the stock file then tune it later. | |||
| 01-26-2026, (Subject: Cm871 RPM shut off ) Post: #14 | |||
| RE: Cm871 RPM shut off He had his friend come and program it, he’s all good! No issues | |||
