| Just did 2 injectors ran2 days now skipping |
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #10 | |||
| RE: Just did 2 injectors ran2 days now skipping My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs. | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #11 | |||
RE: Just did 2 injectors ran2 days now skipping (01-01-2017 )gearhead Wrote: My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs. What kind of torque wrench have you got that records the final number like that for you Gearhead? Mine are atypical Snap-On and Mac click type. User's Signature: Why? Why do I always ask "why?" Because I can't learn or help teach others with "'cause I said so..." | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #12 | |||
RE: Just did 2 injectors ran2 days now skipping (01-01-2017 )Hammerhead Wrote:(01-01-2017 )gearhead Wrote: My torque wrench does torque plus and it reads out torque once torque plus is done and it works out to be about 100ftlbs. i have a snap on digital torque angle and it does this aswell. | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #13 | |||
| RE: Just did 2 injectors ran2 days now skipping | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #14 | |||
| RE: Just did 2 injectors ran2 days now skipping I will look into Quickserve Thanks | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #15 | |||
RE: Just did 2 injectors ran2 days now skipping (01-01-2017 )Rawze Wrote:(12-31-2016 )Hammerhead Wrote: Thanks for the update, I will update my procedure printout! I made sure all the bolt holes were cleaned out and blown out And i was told the rocker arm shafts were torqued at 120 | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #16 | |||
| RE: Just did 2 injectors ran2 days now skipping Yes I am. From Foxboro I saw your truck at the gravel pit a few weeks ago didnt have time to stop and say hello. | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #17 | |||
| RE: Just did 2 injectors ran2 days now skipping UPDATE....I got it all back together to include a new Rocker box Gasket and started it up and it ran like crap it was skipping and smoking....i was panicked :waaaht: so i started to back-check everything i did to make sure i didn't miss anything and decided to unplug one injector at a time to do a back yard cyl balance test as soon as i grabbed the harness it started to run better than like crap again so i removed the new injection harness and installed the old one and it runs great....i cant believe a new harness was defective....i am happy that i did the injectors myself and it will give me the confidence to do the one on my ISX in the future.... | |||
| 01-01-2017, (Subject: Just did 2 injectors ran2 days now skipping ) Post: #18 | |||
RE: Just did 2 injectors ran2 days now skipping (01-01-2017 )earnies2 Wrote: UPDATE....I got it all back together to include a new Rocker box Gasket and started it up and it ran like crap it was skipping and smoking....i was panicked :waaaht: so i started to back-check everything i did to make sure i didn't miss anything and decided to unplug one injector at a time to do a back yard cyl balance test as soon as i grabbed the harness it started to run better than like crap again so i removed the new injection harness and installed the old one and it runs great....i cant believe a new harness was defective....i am happy that i did the injectors myself and it will give me the confidence to do the one on my ISX in the future.... You need to keep in mind that it can take up to 10 minutes+ of running before it runs smooth again after having anything in the fuel system apart. I hope you let it run for a good 10 minutes before making that determination. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
