| My dilemma Cat vs Cummins |
| 10-20-2019, (Subject: My dilemma Cat vs Cummins ) Post: #10 | |||
| RE: My dilemma Cat vs Cummins SDP was the serial number for the last on highway C15 cat built. It has full emissions. | |||
| 10-20-2019, (Subject: My dilemma Cat vs Cummins ) Post: #11 | |||
| RE: My dilemma Cat vs Cummins Adding this here for those who may not know any better... if that IVA valve system is disabled and that thing is going down the roads at 19:1 + compression ratio, its going to keep blowing heads and gaskets. Engine was never designed for that. That system was never designed to go down the road with those valves closed, yet i see about every moron with a yellow motor try to make them do it like complete idiots. just my own 2 cents worth, I am not a cat guy. no one has to agree. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 10-20-2019, (Subject: My dilemma Cat vs Cummins ) Post: #12 | |||
RE: My dilemma Cat vs Cummins (10-20-2019 )tree98 Wrote: SDP was the serial number for the last on highway C15 cat built. It has full emissions. Oh, yes sir. The Regen C15 will bankrupt you. We had 2 of those trucks. Gave one away to another terminal it was constantly giving trouble. The other one stays local now. About the only trouble the CAT accert engines without Regen have given is the intake actuators and the wiring harness that operates them. Not great on fuel mileage but dependable as you could ask for. No EGR valve or EGR cooler to worry with. If I had an C15 Regen engine I would get it setup to run the accert non Regen program and leave it alone. User's Signature: 2015 Kenworth T660 | |||
| 10-20-2019, (Subject: My dilemma Cat vs Cummins ) Post: #13 | |||
RE: My dilemma Cat vs Cummins (10-20-2019 )Rawze Wrote: if that IVA valve system is disabled and that thing is going down the roads at 18:1 + compression ratio, its going to keep blowing heads and gaskets. Engine was never designed for that. That system was never designed to go down the road with those valves closed, yet i see about every moron with a yellow motor try to make them do it like complete idiots. 100% bang on Rawze!! I see guys do that all the time and I just cant believe it. Mine was tuned by Unilevers and had factory 18:1 and iva still active and twin turbos still on. User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
| 10-21-2019, (Subject: My dilemma Cat vs Cummins ) Post: #14 | |||
RE: My dilemma Cat vs Cummins (10-20-2019 )redbeard Wrote: After all you have been through, I believe you know the answer. Well said, and spot on. Thank you. | |||
