| Chassis grease... |
| 06-24-2020, (Subject: Chassis grease... ) Post: #10 | |||
| RE: Chassis grease... I'd never done it that way either until I read the paperwork when I replaced the driveshafts/u-joints. On another note, I think I'll be switching over to the Redline grease....I'm noticing the grease I use now is breaking down in the joints. I'm not liking what I'm seeing come out when new is pumped in. | |||
| 06-24-2020, (Subject: Chassis grease... ) Post: #11 | |||
| RE: Chassis grease... I flush mine until I see fresh, clean grease come out of them.-- always have done it this way, never had an issue... but that is just me. Guess everyone is a bit different.lol -- Most important thing is never let things run dry or get crudded up with old dry grease. Grease does separate too if left in something too long (few years) without a flush. Depends on the components and mfgr I think. I know some tie-rod makers say not to grease past the point of the soft protective boots swelling up... but most u-joints I have seen say to flush them until you see fresh clean grease flowing out from all 4 sides, otherwise something is wrong. There are a couple manufacturers that say not to blow out rubber grease-boots, and some that say to always flush old grease. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 06-24-2020, (Subject: Chassis grease... ) Post: #12 | |||
| RE: Chassis grease... I have been using Royal Redmax grease. Swipped it from work. Kinda of hard to find it. There is a distributor here local to me. User's Signature: 2015 Kenworth T660 | |||
| 06-25-2020, (Subject: Chassis grease... ) Post: #13 | |||
| RE: Chassis grease... I flush mine until grease starts to come out and I hear air purge, per Spicer. User's Signature: 2010 T2000, CM871, 13spd, 1.173m, tanker yanker Overhauled @ 927k | |||
| 04-09-2023, (Subject: Chassis grease... ) Post: #14 | |||
RE: Chassis grease... (06-23-2020 )JMBT Wrote: I use a green poly urea based grease, forumulated for marine applications. I use it because it is the only thing I have found that doesn’t seem to wash out in wet conditions. One time last year I ran FL to NM and was in the rain the entire time, no shi#t, the whole time. When I got under to grease after delivery there was still grease showing on my slack adjusters. I am not saying it’s the best thing ever, but it works well for me. What Brand? | |||
| 04-09-2023, (Subject: Chassis grease... ) Post: #15 | |||
RE: Chassis grease... (06-23-2020 )dhirocz Wrote: That's the reason for my post. I'd rather find what works and stick with it. What brand of Green and what brand of Red? | |||
