Turbo testing...
02-26-2021, (Subject: Turbo testing... )
RE: Turbo testing...
So when you guys blocked the turbo and aired up the system you found the leak at the compressor, right? I’ll have to give that a try. Did you hear it back feeding through the compressor, or how were you able to verify the compressor was leaking?
If the compressor is the culprit would I notice that the compressed air system wasn’t performing as usual?
 Thanks given by: tree98
air hissing out the oil fill tube.
we narrowed it down by pressurizing the intake manifold side ...w as still there, then the compressor separately.
 Thanks given by: JMBT , tree98
Thank you sir. I will be doing this test. It sounds like a more likely suspect then the turbo at this point.
