Got a another Volvo but with a D12
05-31-2021, (Subject: Got a another Volvo but with a D12 )
RE: Got a another Volvo but with a D12
i think the easiest way to get tripac/carrier AC/Heat is get a carrier HVAC unit which heats and cools is it as a good as cutting a hole in the roof/or rear of sleeper and using a RV AC unit no..but it just mounts under your bed just have to run the 120v to it. then just get a good diesel genset or gas if you wanna be running to other side of truck stops for gas. i would look for a genset with 30amp 120v to gaurentee full power for the AC on the carrier HVAC Unit.
06-01-2021, (Subject: Got a another Volvo but with a D12 )
I'm not sure what your suggesting here Lonestar10? Picture of the unit might make it more clear.
(05-31-2021 )Lonestar10 Wrote:  i think the easiest way to get tripac/carrier AC/Heat is get a carrier HVAC unit which heats and cools is it as a good as cutting a hole in the roof/or rear of sleeper and using a RV AC unit no..but it just mounts under your bed just have to run the 120v to it. then just get a good diesel genset or gas if you wanna be running to other side of truck stops for gas. i would look for a genset with 30amp 120v to gaurentee full power for the AC on the carrier HVAC Unit.
im having a hard time understanding what you mean?
